跳转到主内容
Lenovo 100s Chromebook-11IBY Screen Replacement
你所需要的
  1. Lenovo 100s Chromebook-11IBY Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Ensure your device is turned off and unplugged.
  2. Lenovo 100s Chromebook-11IBY Screen Replacement: 步骤 2 中的图像 1,1
    • Use the plastic opening tool on the recessed notch to gently pry each side of around the screen up.
  3. Lenovo 100s Chromebook-11IBY Screen Replacement: 步骤 3 中的图像 1,2 Lenovo 100s Chromebook-11IBY Screen Replacement: 步骤 3 中的图像 2,2
    • Carefully pry up and underneath both the (left & right) hinges of the screen cover.
  4. Lenovo 100s Chromebook-11IBY Screen Replacement: 步骤 4 中的图像 1,1
    • Use the opening tool on the inside of the screen plate and again on the sides to gently remove it.
  5. Lenovo 100s Chromebook-11IBY Screen Replacement: 步骤 5 中的图像 1,2 Lenovo 100s Chromebook-11IBY Screen Replacement: 步骤 5 中的图像 2,2
    • Use the #0 Phillips screwdriver to remove the four 6mm screws from the screen.
  6. Lenovo 100s Chromebook-11IBY Screen Replacement: 步骤 6 中的图像 1,1
    • Gently remove the screen from the plate and place it on the keyboard.
    • Be careful not to pull screen the immediately or completely out because cables are attached.
  7. Lenovo 100s Chromebook-11IBY Screen Replacement: 步骤 7 中的图像 1,1
    • Gently remove the adhesive tape from the back of the screen.
  8. Lenovo 100s Chromebook-11IBY Screen Replacement: 步骤 8 中的图像 1,1
    • Unplug the screen from the laptop.
  9. Lenovo 100s Chromebook-11IBY Screen Replacement: 步骤 9 中的图像 1,2 Lenovo 100s Chromebook-11IBY Screen Replacement: 步骤 9 中的图像 2,2
    • The screen may now be removed completely from the laptop.
    • The back side of the screen has the screen's model number and manufacturer.
结论
另外一个人完成了本指南。
Milton Perez
于03/09/17注册
630 声望
创作了5篇指南
团队
USF Tampa, Team S7-G2, Cagle Spring 2017 USF Tampa, Team S7-G2, Cagle Spring 2017 的会员
USFT-CAGLE-S17S7G2
1 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 10
总计 1,683
