跳转到主内容
Lenovo 100e Chromebook 2nd Gen Trackpad Replacement
你所需要的
  1. Lenovo 100e Chromebook 2nd Gen Trackpad Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Remove the nine 6 mm screws from the back of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 100e Chromebook 2nd Gen Trackpad Replacement: 步骤 2 中的图像 1,2 Lenovo 100e Chromebook 2nd Gen Trackpad Replacement: 步骤 2 中的图像 2,2
    • Open the laptop and lay it flat.
    • Go along the edge of the keyboard with an opening tool until it pops loose.
    • Potential for device damage: Make sure that the keyboard does not fall away from the laptop, as it is still connected to the internal components
  3. Lenovo 100e Chromebook 2nd Gen Trackpad Replacement: 步骤 3 中的图像 1,2 Lenovo 100e Chromebook 2nd Gen Trackpad Replacement: 步骤 3 中的图像 2,2
    • Lift the keyboard connectors up using an opening pick.
    • Remove the connectors from their sockets.
  4. Lenovo 100e Chromebook 2nd Gen Trackpad Replacement, Trackpad: 步骤 4 中的图像 1,1
    • Remove the three 2 mm Phillips #00 screws holding the trackpad in.
  5. Lenovo 100e Chromebook 2nd Gen Trackpad Replacement: 步骤 5 中的图像 1,2 Lenovo 100e Chromebook 2nd Gen Trackpad Replacement: 步骤 5 中的图像 2,2
    • Push up on the side of the trackpad that faces the screen.
    • Pop the trackpad out and remove it from the laptop.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 13
过去 30 天: 61
总计 1,364
