跳转到主内容
Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement
你所需要的
  1. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Remove the nine 6 mm screws from the back of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: 步骤 2 中的图像 1,2 Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: 步骤 2 中的图像 2,2
    • Open the laptop and lay it flat.
    • Go along the edge of the keyboard with an opening tool until it pops loose.
    • Potential for device damage: Make sure that the keyboard does not fall away from the laptop, as it is still connected to the internal components
  3. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: 步骤 3 中的图像 1,2 Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: 步骤 3 中的图像 2,2
    • Lift the keyboard connectors up using an opening pick.
    • Remove the connectors from their sockets.
  4. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement, Headphone Jack: 步骤 4 中的图像 1,1
    • Remove the three 4 mm Phillips #0 screws holding the headphone jack in place.
  5. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: 步骤 5 中的图像 1,1
    • Using a plastic opening pick, remove the connection between the aux port and the speakers.
  6. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: 步骤 6 中的图像 1,1
    • Using the plastic opening pick, pop the retaining flap holding the ribbon cable in place.
    • Remove the headphone jack from the laptop.
结论
一条评论
I believe our model has the headphone jack soldered on. Any other ideas?
L Hart - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 13
总计 957
