跳转到主内容
Lenovo 100e Chromebook 2nd Gen Display Replacement
你所需要的
  1. Lenovo 100e Chromebook 2nd Gen Display Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Remove the nine 6 mm screws from the back of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 100e Chromebook 2nd Gen Display Replacement: 步骤 2 中的图像 1,2 Lenovo 100e Chromebook 2nd Gen Display Replacement: 步骤 2 中的图像 2,2
    • Open the laptop and lay it flat.
    • Go along the edge of the keyboard with an opening tool until it pops loose.
    • Potential for device damage: Make sure that the keyboard does not fall away from the laptop, as it is still connected to the internal components
  3. Lenovo 100e Chromebook 2nd Gen Display Replacement: 步骤 3 中的图像 1,2 Lenovo 100e Chromebook 2nd Gen Display Replacement: 步骤 3 中的图像 2,2
    • Lift the keyboard connectors up using an opening pick.
    • Remove the connectors from their sockets.
  4. Lenovo 100e Chromebook 2nd Gen Display Replacement, Battery: 步骤 4 中的图像 1,1
    • Remove the four 4 mm Phillips #0 screws holding the battery in.
  5. Lenovo 100e Chromebook 2nd Gen Display Replacement: 步骤 5 中的图像 1,1
    • Using an opening pick, push on the connection where the wires are connected to the motherboard.
    • Potential for device damage: This step takes some force to disconnect, but be careful to not pull the wires out of the battery.
  6. Lenovo 100e Chromebook 2nd Gen Display Replacement: 步骤 6 中的图像 1,1
    • The battery is now loose and can be removed from the laptop.
  7. Lenovo 100e Chromebook 2nd Gen Display Replacement, Screen Bezel: 步骤 7 中的图像 1,1
    • Using a spudger, go along the edge of the screen and pop the connections between the cover and the back side out.
  8. Lenovo 100e Chromebook 2nd Gen Display Replacement: 步骤 8 中的图像 1,1
    • Insert the spudger into the gap between the hinges and pull up to detach the connections.
  9. Lenovo 100e Chromebook 2nd Gen Display Replacement: 步骤 9 中的图像 1,1
    • Remove the screen bezel from the laptop.
  10. Lenovo 100e Chromebook 2nd Gen Display Replacement, Display: 步骤 10 中的图像 1,1
    • Remove the four 3.4 mm screws holding the screen in place using the Phillips #00 screwdriver.
  11. Lenovo 100e Chromebook 2nd Gen Display Replacement: 步骤 11 中的图像 1,1
    • Carefully pull the screen back onto the lower assembly.
  12. Lenovo 100e Chromebook 2nd Gen Display Replacement: 步骤 12 中的图像 1,3 Lenovo 100e Chromebook 2nd Gen Display Replacement: 步骤 12 中的图像 2,3 Lenovo 100e Chromebook 2nd Gen Display Replacement: 步骤 12 中的图像 3,3
    • Peel back the protective tape over the display cable using the spudger.
    • Gently lift the black bar latch holding the cable in place, until the cable becomes loose.
    • Pull the cable free and remove the display.
    • DO NOT pull on the cable before lifting the bar latch or the cable will break.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 17
过去 30 天: 112
总计 2,043
