跳转到主内容
Lenovo 100e Chromebook 2nd Gen Camera Replacement
你所需要的
  1. Lenovo 100e Chromebook 2nd Gen Camera Replacement, Screen Bezel: 步骤 1 中的图像 1,1
    • Using a spudger, go along the edge of the screen and pop the connections between the cover and the back side out.
  2. Lenovo 100e Chromebook 2nd Gen Camera Replacement: 步骤 2 中的图像 1,1
    • Insert the spudger into the gap between the hinges and pull up to detach the connections.
  3. Lenovo 100e Chromebook 2nd Gen Camera Replacement: 步骤 3 中的图像 1,1
    • Remove the screen bezel from the laptop.
  4. Lenovo 100e Chromebook 2nd Gen Camera Replacement, Camera: 步骤 4 中的图像 1,1
    • Using the opening pick, pry the camera from the front of the laptop.
  5. Lenovo 100e Chromebook 2nd Gen Camera Replacement: 步骤 5 中的图像 1,1
    • Carefully pinch and pull on the connection between the camera and the motherboard.
    • The camera is now loose and can be removed.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 14
总计 531
