跳转到主内容
Lenovo 100e Chromebook 2nd Gen Battery Replacement
你所需要的
  1. Lenovo 100e Chromebook 2nd Gen Battery Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Remove the nine 6 mm screws from the back of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 100e Chromebook 2nd Gen Battery Replacement: 步骤 2 中的图像 1,2 Lenovo 100e Chromebook 2nd Gen Battery Replacement: 步骤 2 中的图像 2,2
    • Open the laptop and lay it flat.
    • Go along the edge of the keyboard with an opening tool until it pops loose.
    • Potential for device damage: Make sure that the keyboard does not fall away from the laptop, as it is still connected to the internal components
  3. Lenovo 100e Chromebook 2nd Gen Battery Replacement: 步骤 3 中的图像 1,2 Lenovo 100e Chromebook 2nd Gen Battery Replacement: 步骤 3 中的图像 2,2
    • Lift the keyboard connectors up using an opening pick.
    • Remove the connectors from their sockets.
  4. Lenovo 100e Chromebook 2nd Gen Battery Replacement, Battery: 步骤 4 中的图像 1,1
    • Remove the four 4 mm Phillips #0 screws holding the battery in.
  5. Lenovo 100e Chromebook 2nd Gen Battery Replacement: 步骤 5 中的图像 1,1
    • Using an opening pick, push on the connection where the wires are connected to the motherboard.
    • Potential for device damage: This step takes some force to disconnect, but be careful to not pull the wires out of the battery.
  6. Lenovo 100e Chromebook 2nd Gen Battery Replacement: 步骤 6 中的图像 1,1
    • The battery is now loose and can be removed from the laptop.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 30
过去 30 天: 107
总计 2,576
