当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Apply pressure to the bottom plate and it will pop off.
From here, you can replace the bottom plate, or continue on to further steps.
Having opened the camera and removed the bottom plate, unscrew the five screws marked in the picture.
The screw marked in blue is a tiny bit harder to find because it's in a crevice. Don't miss it!
Now that you've removed the bottom plate, you can pull apart the front and back covers.
Start with the front cover and, by applying pressure (perhaps a lot of pressure), snap off the front cover.
Next, the back cover.
Apply pressure to remove the back plate.
Be careful of the buttons on the top of the camera falling off, they are small parts and CAN get lost easily.
The best way to remove the back is to stick your thumbs on either side of the battery socket and separate from there.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
