本指南有最近更改,您可查看未经巡查的最新版本。
你所需要的
Carefully unscrew the four Phillips #0 screws on the bottom of the camera.
Apply pressure to the bottom plate and it will pop off.
From here, you can replace the bottom plate, or continue on to further steps.
Having opened the camera and removed the bottom plate, unscrew the five screws marked in the picture.
The screw marked in blue is a tiny bit harder to find because it's in a crevice. Don't miss it!
Now that the lens motor has been removed, you can apply pressure to the back of the lens and push it out.
From here, locate the three screws near the front of the lens.
Unscrew these three screws.
另外一个人完成了本指南。
