本指南有最近更改,您可查看未经巡查的最新版本。
简介
Use this guide to replace the Flash Diffuser.
你所需要的
Carefully unscrew the four Phillips #0 screws on the bottom of the camera.
Apply pressure to the bottom plate and it will pop off.
From here, you can replace the bottom plate, or continue on to further steps.
Now that you've removed the bottom plate, you can pull apart the front and back covers.
Start with the front cover and, by applying pressure (perhaps a lot of pressure), snap off the front cover.
另外一个人完成了本指南。
