跳转到主内容
Leica Z2X Flash Diffuser Replacement
你所需要的
  1. Leica Z2X Flash Diffuser Replacement, Remove the Bottom Screws: 步骤 1 中的图像 1,1
    • Carefully unscrew the four Phillips #0 screws on the bottom of the camera.
    • There is a screw located inside of the tripod hole (large circle.) Make sure the screw is removed from there too!
  2. Leica Z2X Flash Diffuser Replacement, Open the Back Door: 步骤 2 中的图像 1,1
    • Open the back door on the camera by pushing down on the door latch.
  3. Leica Z2X Flash Diffuser Replacement, Remove the Bottom Plate: 步骤 3 中的图像 1,1
    • Apply pressure to the bottom plate and it will pop off.
    • From here, you can replace the bottom plate, or continue on to further steps.
  4. Leica Z2X Flash Diffuser Replacement, Flash Diffuser: 步骤 4 中的图像 1,1
    • Now that you've removed the bottom plate, you can pull apart the front and back covers.
    • Start with the front cover and, by applying pressure (perhaps a lot of pressure), snap off the front cover.
  5. Leica Z2X Flash Diffuser Replacement: 步骤 5 中的图像 1,1
    • Next, the back cover.
    • Apply pressure to remove the back plate.
    • Be careful of the buttons on the top of the camera falling off, they are small parts and CAN get lost easily.
    • The best way to remove the back is to stick your thumbs on either side of the battery socket and separate from there.
  6. Leica Z2X Flash Diffuser Replacement: 步骤 6 中的图像 1,1
    • You should now have removed the front and back plates.
  7. Leica Z2X Flash Diffuser Replacement: 步骤 7 中的图像 1,1
    • Removing the flash diffuser should be simple from here.
    • Simply take the front cover and apply pressure to the front of the flash diffuser and it should pop right out.
结论
另外一个人完成了本指南。
Kenny
于04/10/11注册
57 声望
创作了3篇指南
团队
Cal Poly, Team 18-19, Garner Spring 2011 Cal Poly, Team 18-19, Garner Spring 2011 的会员
CPSU-GARNER-S11S18G19
4 名成员
创作了13篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 21
总计 3,531
