跳转到主内容
Leica CS20 Screen Replacement
  1. Leica CS20 Screen Replacement, Oops..: 步骤 1 中的图像 1,1
    • I did it again!
  2. Leica CS20 Screen Replacement, Order a new replacement screen: 步骤 2 中的图像 1,1
    • I am tired to pay 1200 EUR to Leica service center, so I ordered a new replacement screent here: www.xsurveying.com/product/new-leica-cs20-digitizer-screen-replacement Price with delivery was around 185 EUR
  3. Leica CS20 Screen Replacement, New touchscreen: 步骤 3 中的图像 1,1
    • The package arrived in two weeks. It contained a well packed touchscreen
  4. Leica CS20 Screen Replacement, Prepare a clean area: 步骤 4 中的图像 1,1
    • Place controller on a desk
  5. Leica CS20 Screen Replacement, Unscrew all the bolts: 步骤 5 中的图像 1,1
    • …and unscrew all the bolts
  6. Leica CS20 Screen Replacement, Remove the bottom lid: 步骤 6 中的图像 1,1
    • Also, remove the bottom plastic lid
  7. Leica CS20 Screen Replacement, Unscrew two black bolts: 步骤 7 中的图像 1,1
    • …in order to unscrew these two black bolts. Place them separately.
  8. Leica CS20 Screen Replacement, Unscrew 2 bolts: 步骤 8 中的图像 1,1
    • These bolts also should be unscrewed.
  9. Leica CS20 Screen Replacement, Remove the back cover: 步骤 9 中的图像 1,1
    • After that the controller’s back wall can be removed
  10. Leica CS20 Screen Replacement, Unscrew four bolts: 步骤 10 中的图像 1,1
    • Unscrew these four bolts
  11. Leica CS20 Screen Replacement, Unscrew two bolts: 步骤 11 中的图像 1,1
    • Unscrew these two small bolts. Place them separately.
  12. Leica CS20 Screen Replacement, Unscrew two plastic bolts: 步骤 12 中的图像 1,1
    • Unscrew these two plastic bolts. Place them separately.
  13. Leica CS20 Screen Replacement, Unscrew two bolts: 步骤 13 中的图像 1,1
    • Now the last two bolts can be unscrewed
  14. Leica CS20 Screen Replacement, Remove the cage: 步骤 14 中的图像 1,1
    • This GNSS antenna connector will be disconnected when you pull out the metal cage
  15. Leica CS20 Screen Replacement, Pull out the board: 步骤 15 中的图像 1,1
    • …than pull out this board carefully
  16. Leica CS20 Screen Replacement, See theribbon cable: 步骤 16 中的图像 1,1
    • So you wil get an access to this ribbon cable
  17. Leica CS20 Screen Replacement, Unclip the connector: 步骤 17 中的图像 1,1
    • ...unclip it!
  18. Leica CS20 Screen Replacement, Unclip the connector: 步骤 18 中的图像 1,1
    • Also, unclip the kyocera-connector to this ribbon cable
  19. Leica CS20 Screen Replacement, Act carefully!: 步骤 19 中的图像 1,1
    • Proceed with great caution!
  20. Leica CS20 Screen Replacement, Unclip the cable: 步骤 20 中的图像 1,1
    • Unclip the touchscreen ribbon cable
  21. Leica CS20 Screen Replacement, Remove the whole board: 步骤 21 中的图像 1,1
    • Now you are able to remove the whole board…
  22. Leica CS20 Screen Replacement, Change the screen!: 步骤 22 中的图像 1,1
    • And finally, change the screen!
结论
附加文件
Sandu Tuzarean
于04/01/25注册
345 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 16
过去 30 天: 52
总计 228
