跳转到主内容
Lego Dimensions Starter Pack USB Cable Replacement
你所需要的
  1. Lego Dimensions Starter Pack USB Cable Replacement, Top Cover Parts: 步骤 1 中的图像 1,2 Lego Dimensions Starter Pack USB Cable Replacement, Top Cover Parts: 步骤 1 中的图像 2,2
    • Be careful not to crack the cover.
    • Use the metal spudger to gently pry open the corners of the top cover.
  2. Lego Dimensions Starter Pack USB Cable Replacement: 步骤 2 中的图像 1,1
    • Be careful not to crack the top cover.
    • Use the metal spudger to gently pry up the center of the top cover.
  3. Lego Dimensions Starter Pack USB Cable Replacement: 步骤 3 中的图像 1,1
    • Pull the top cover off.
  4. Lego Dimensions Starter Pack USB Cable Replacement: 步骤 4 中的图像 1,1
    • Lift up the circular illumination stand and remove it from the toy pad.
  5. Lego Dimensions Starter Pack USB Cable Replacement: 步骤 5 中的图像 1,1
    • Lift up the white L-shaped pieces and remove them from the toy pad.
  6. Lego Dimensions Starter Pack USB Cable Replacement, USB Cable: 步骤 6 中的图像 1,1
    • Pull the white connector away from the motherboard, keeping the white connector parallel to the board.
    • You may need to use a plastic opening tool or spudger to help separate the connector. Avoid pulling firmly on the wires themselves.
    • Remove the USB cable from the toy pad.
结论
3等其他人完成本指南。
Alyssa Lach
于11/06/17注册
509 声望
创作了4篇指南
团队
IUPUI, Team S5-G2, Baechle Fall 2017 IUPUI, Team S5-G2, Baechle Fall 2017 的会员
IUPUI-BAECHLE-F17S5G2
2 名成员
创作了8篇指南
2条评论
Where do you buy the USB cable from?
jaimea371 - 回复
mguzmanv - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 31
总计 5,328
