跳转到主内容
Left Temple
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Left Temple, Remove the screw covers: 步骤 1 中的图像 1,2 Left Temple, Remove the screw covers: 步骤 1 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers to remove the six screw covers from the left temple.
  2. Left Temple, Unfasten the left temple: 步骤 2 中的图像 1,2 Left Temple, Unfasten the left temple: 步骤 2 中的图像 2,2
    • Use a T5 Torx screwdriver to remove the six 4.9 mm‑long screws securing the two left temple halves.
    • Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing the left hinge cover.
  3. Left Temple, Remove the outer hinge cover: 步骤 3 中的图像 1,3 Left Temple, Remove the outer hinge cover: 步骤 3 中的图像 2,3 Left Temple, Remove the outer hinge cover: 步骤 3 中的图像 3,3
    • Insert the flat end of a spudger in the gap between the left outer and inner hinge covers.
    • Slide the spudger along the gap to separate the clips securing the outer hinge cover.
    • Remove the outer hinge cover.
  4. Left Temple, Remove the left temple: 步骤 4 中的图像 1,2 Left Temple, Remove the left temple: 步骤 4 中的图像 2,2
    • Pull the left temple out of its slot in the hinge.
    • Don't try to fully remove it yet, as it's still connected by a cable.
  5. Left Temple: 步骤 5 中的图像 1,2 Left Temple: 步骤 5 中的图像 2,2
    • Insert the flat end of a spudger in the gap between the outer and inner temple.
    • Slide the spudger along the gap to separate the plastic clips securing the outer temple.
  6. Left Temple: 步骤 6 中的图像 1,2 Left Temple: 步骤 6 中的图像 2,2
    • Pull the outer temple off of its inner half to completely release its plastic clips.
  7. Left Temple: 步骤 7 中的图像 1,2 Left Temple: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    Tesa 61395 Tape
    $6.99
    • The speaker is lightly adhered to the outer temple.
    • Slide the flat end of a spudger under the speaker to separate its adhesive.
    • Let the speaker rest next to the headset before continuing.
    • During reassembly, if your speaker adhesive isn't sticky, use Tesa 61395 Tape to re-adhere the speaker to the outer temple.
  8. Left Temple, Peel the hinge tape: 步骤 8 中的图像 1,2 Left Temple, Peel the hinge tape: 步骤 8 中的图像 2,2
    • Use tweezers to peel back the black tape covering one of the inner hinge cover screws.
  9. Left Temple, Unfasten the inner hinge cover: 步骤 9 中的图像 1,1
    • Use a T5 Torx screwdriver to remove the two screws securing the inner hinge cover:
    • One 3.5 mm‑long screw
    • One 4.9 mm‑long screw
  10. Left Temple, Reposition the inner hinge cover: 步骤 10 中的图像 1,3 Left Temple, Reposition the inner hinge cover: 步骤 10 中的图像 2,3 Left Temple, Reposition the inner hinge cover: 步骤 10 中的图像 3,3
    • Don't fully remove the inner hinge cover, as it's connected by the volume button cable.
    • Rotate the inner hinge cover off its groove in the frame.
    • Let the cover hang off its volume button cable for now.
结论
Alex Diaz-Kokaisl
于01/16/22注册
215,598 声望
创作了1,046篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,818篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 79
