跳转到主内容
Leapfrog My Own Leaptop Speaker Replacement Guide
你所需要的
  1. Leapfrog My Own Leaptop Speaker Replacement Guide, Battery: 步骤 1 中的图像 1,1
    • Flip over device so that back portion of the device is facing you.
  2. Leapfrog My Own Leaptop Speaker Replacement Guide: 步骤 2 中的图像 1,1
    • Unscrew the one 10mm screw that holds the battery cover in place with a a PH1 phillips head screwdriver.
    • Please note that the screw cannot be removed as it is attached to the battery cover.
  3. Leapfrog My Own Leaptop Speaker Replacement Guide: 步骤 3 中的图像 1,2 Leapfrog My Own Leaptop Speaker Replacement Guide: 步骤 3 中的图像 2,2
    • Carefully pry the batteries out with a plastic opening tool prying from the non spring side.
    • Remove the three AA batteries.
    • Note the direction of the batteries for when reassembling.
  4. Leapfrog My Own Leaptop Speaker Replacement Guide, Speaker: 步骤 4 中的图像 1,1
    • Remove the eleven 10mm screws from the back of the device with a a PH1 phillips head screwdriver.
  5. Leapfrog My Own Leaptop Speaker Replacement Guide: 步骤 5 中的图像 1,1
    • Carefully remove back of the device.
    • Make sure not to rip the wires when lifting the cover off.
  6. Leapfrog My Own Leaptop Speaker Replacement Guide: 步骤 6 中的图像 1,2 Leapfrog My Own Leaptop Speaker Replacement Guide: 步骤 6 中的图像 2,2
    • Unscrew the two 7.5 mm screws to the left and right of the speaker with a PH1 phillips head screwdriver.
    • Remove the cover and place to the side.
  7. Leapfrog My Own Leaptop Speaker Replacement Guide: 步骤 7 中的图像 1,2 Leapfrog My Own Leaptop Speaker Replacement Guide: 步骤 7 中的图像 2,2
    • Once the cover is removed, gently lift up the speaker making sure not to rip or break the wires.
    • If you are disassembling the device to clean the speaker, clean it at this point with a soft, lightly dampened cloth.
    • Gently turn the speaker over and carefully desolder the white and yellow wires from the speaker.
结论
Any issues that cannot be resolved with any portion of this wiki please contact Leapfrog Customer Serivce
3等其他人完成本指南。
Jonathan Fitzer
于02/10/16注册
584 声望
创作了3篇指南
团队
USF Tampa, Team 14-6, Lacy Spring 2016 USF Tampa, Team 14-6, Lacy Spring 2016 的会员
USFT-LACY-S16S14G6
4 名成员
创作了6篇指南
5条评论
Thanks for this very useful instruction. Where can I buy a replacement speaker?
-Don
Don La - 回复
I agree, but I also second the question...where can I buy a replacement speaker?
Jimmy Liang - 回复
Where could I purchase a replacement speaker?
Zuzi - 回复
Where could I buy the replacement speaker in Malaysia?
stanley.met - 回复
Where can I buy replacement speaker in Malaysia? Appreciate yr reply
ribenabona - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 13
过去 30 天: 44
总计 6,471
