跳转到主内容
Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide
你所需要的
  1. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide, Battery: 步骤 1 中的图像 1,1
    • Flip over device so that back portion of the device is facing you.
  2. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 步骤 2 中的图像 1,1
    • Unscrew the one 10mm screw that holds the battery cover in place with a a PH1 phillips head screwdriver.
    • Please note that the screw cannot be removed as it is attached to the battery cover.
  3. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 步骤 3 中的图像 1,2 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 步骤 3 中的图像 2,2
    • Carefully pry the batteries out with a plastic opening tool prying from the non spring side.
    • Remove the three AA batteries.
    • Note the direction of the batteries for when reassembling.
  4. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide, Keyboard Buttons: 步骤 4 中的图像 1,1
    • Remove the eleven 10mm screws from the back of the device with a a PH1 phillips head screwdriver.
  5. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 步骤 5 中的图像 1,1
    • Carefully remove back of the device.
    • Make sure not to rip the wires when lifting the cover off.
  6. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 步骤 6 中的图像 1,2 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 步骤 6 中的图像 2,2
    • Remove the three 10mm screws from the upper left hand corner white plastic piece with a PH1 phillips head screwdriver.
    • Unscrew the five 4mm screws from the plastic membrane with a PH1 phillips head screwdriver.
  7. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 步骤 7 中的图像 1,1
    • Remove the white plastic piece and place it to the side.
  8. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 步骤 8 中的图像 1,3 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 步骤 8 中的图像 2,3 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 步骤 8 中的图像 3,3
    • Gently grab the membrane and peal it upwards.
    • Carefully remove the membrane and set it to the side.
    • From this step you can also clean the membrane of any residue with a lightly dampened paper towel.
    • Ensure that the membrane is completely dry before reassembly.
  9. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 步骤 9 中的图像 1,2 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 步骤 9 中的图像 2,2
    • Gently lift and remove the foam piece
  10. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 步骤 10 中的图像 1,3 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 步骤 10 中的图像 2,3 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 步骤 10 中的图像 3,3
    • From here, each button is able to be removed for cleaning or replacement.
    • Using a tweezers or needle nose pliers, remove the necessary pieces from the device.
结论
2等其他人完成本指南。
Jonathan Fitzer
于02/10/16注册
584 声望
创作了3篇指南
团队
USF Tampa, Team 14-6, Lacy Spring 2016 USF Tampa, Team 14-6, Lacy Spring 2016 的会员
USFT-LACY-S16S14G6
4 名成员
创作了6篇指南
6条评论
Very useful. but where to get a new membrane? please help
Alina Timchenko - 回复
Didn't work. I'll buy a new toy.
victoria_nglover19 - 回复
Is the screen on this suppose to light up?
stewartmelinda41 - 回复
I was wondering if the screen is suppose to light up because the one I have doesnt
thank you very much
Njabulo Mbele - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 23
总计 4,949
