跳转到主内容
Leapfrog My Own Leaptop Battery Replacement Guide
你所需要的
  1. Leapfrog My Own Leaptop Battery Replacement Guide, Battery: 步骤 1 中的图像 1,1
    • Flip over device so that back portion of the device is facing you.
  2. Leapfrog My Own Leaptop Battery Replacement Guide: 步骤 2 中的图像 1,1
    • Unscrew the one 10mm screw that holds the battery cover in place with a a PH1 phillips head screwdriver.
    • Please note that the screw cannot be removed as it is attached to the battery cover.
  3. Leapfrog My Own Leaptop Battery Replacement Guide: 步骤 3 中的图像 1,2 Leapfrog My Own Leaptop Battery Replacement Guide: 步骤 3 中的图像 2,2
    • Carefully pry the batteries out with a plastic opening tool prying from the non spring side.
    • Remove the three AA batteries.
    • Note the direction of the batteries for when reassembling.
终点
另外一个人完成了本指南。
Jonathan Fitzer
于02/10/16注册
584 声望
创作了3篇指南
团队
USF Tampa, Team 14-6, Lacy Spring 2016 USF Tampa, Team 14-6, Lacy Spring 2016 的会员
USFT-LACY-S16S14G6
4 名成员
创作了6篇指南
一条评论
Hi Jonathan! Your article is very helpful. But I have a big question now. I have opened the leaptop and see that membrane should be replaced. But where can I buy the membrane separately? Please help!
Alina Timchenko - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 15
过去 30 天: 53
总计 2,593
