跳转到主内容
Leapfrog LeapPad 3 Speaker Replacement
你所需要的
  1. Leapfrog LeapPad 3 Speaker Replacement, Battery: 步骤 1 中的图像 1,3 Leapfrog LeapPad 3 Speaker Replacement, Battery: 步骤 1 中的图像 2,3 Leapfrog LeapPad 3 Speaker Replacement, Battery: 步骤 1 中的图像 3,3
    • Before taking apart your device, ensure that it is turned off and that your anti-static wrist strap is secured to a ground.
    • Remove the six 10.0 mm Phillips #0 screws from the outer case and remove the cover with your hands.
    • You will not need to pry the case off.
  2. Leapfrog LeapPad 3 Speaker Replacement: 步骤 2 中的图像 1,3 Leapfrog LeapPad 3 Speaker Replacement: 步骤 2 中的图像 2,3 Leapfrog LeapPad 3 Speaker Replacement: 步骤 2 中的图像 3,3
    • Unplug the battery from the motherboard with your hands.
    • The battery sits to the right of the motherboard.
  3. Leapfrog LeapPad 3 Speaker Replacement: 步骤 3 中的图像 1,2 Leapfrog LeapPad 3 Speaker Replacement: 步骤 3 中的图像 2,2
    • Pry the battery gently off of the plastic platform with an opening tool.
    • Do not to puncture the battery, as the material inside can be dangerous.
  4. Leapfrog LeapPad 3 Speaker Replacement, Speaker: 步骤 4 中的图像 1,2 Leapfrog LeapPad 3 Speaker Replacement, Speaker: 步骤 4 中的图像 2,2
    • Disconnect the audio cord from the motherboard using a plastic opening tool.
    • When re-plugging this cord be sure it is flush with the slot, otherwise the speaker and directional pad will malfunction.
    • Use caution when unplugging, and re-plugging the ribbon cord as they are fragile.
  5. Leapfrog LeapPad 3 Speaker Replacement: 步骤 5 中的图像 1,3 Leapfrog LeapPad 3 Speaker Replacement: 步骤 5 中的图像 2,3 Leapfrog LeapPad 3 Speaker Replacement: 步骤 5 中的图像 3,3
    • Unscrew the five 6.0 mm phillips head screws from the board containing the audio jack and directional pad.
  6. Leapfrog LeapPad 3 Speaker Replacement: 步骤 6 中的图像 1,3 Leapfrog LeapPad 3 Speaker Replacement: 步骤 6 中的图像 2,3 Leapfrog LeapPad 3 Speaker Replacement: 步骤 6 中的图像 3,3
    • Unscrew the three 6.5 mm phillips head screws holding down the speaker to the right of the audio jack.
    • Remove the board and speaker from the device.
结论
2等其他人完成本指南。
Matt Irvine
于02/04/16注册
952 声望
创作了6篇指南
团队
USF Tampa, Team 16-2, Blackwell Winter 2016 USF Tampa, Team 16-2, Blackwell Winter 2016 的会员
USFT-BLACKWELL-W16S16G2
3 名成员
创作了12篇指南
一条评论
Where can I purchase a replacement audio board /speaker for the LeapPad3?
lizchilds - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 841
