跳转到主内容
Leapfrog LeapPad 3 Display Assembly Replacement
你所需要的
视频概述
  1. Leapfrog LeapPad 3 Display Assembly Replacement, Battery: 步骤 1 中的图像 1,3 Leapfrog LeapPad 3 Display Assembly Replacement, Battery: 步骤 1 中的图像 2,3 Leapfrog LeapPad 3 Display Assembly Replacement, Battery: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
    购买
    • Before taking apart your device, ensure that it is turned off and that your anti-static wrist strap is secured to a ground.
    • Remove the six 10.0 mm Phillips #0 screws from the outer case and remove the cover with your hands.
    • You will not need to pry the case off.
  2. Leapfrog LeapPad 3 Display Assembly Replacement: 步骤 2 中的图像 1,3 Leapfrog LeapPad 3 Display Assembly Replacement: 步骤 2 中的图像 2,3 Leapfrog LeapPad 3 Display Assembly Replacement: 步骤 2 中的图像 3,3
    • Unplug the battery from the motherboard with your hands.
    • The battery sits to the right of the motherboard.
  3. Leapfrog LeapPad 3 Display Assembly Replacement: 步骤 3 中的图像 1,2 Leapfrog LeapPad 3 Display Assembly Replacement: 步骤 3 中的图像 2,2
    • Pry the battery gently off of the plastic platform with an opening tool.
    • Do not to puncture the battery, as the material inside can be dangerous.
  4. Leapfrog LeapPad 3 Display Assembly Replacement, Speaker: 步骤 4 中的图像 1,2 Leapfrog LeapPad 3 Display Assembly Replacement, Speaker: 步骤 4 中的图像 2,2
    • Disconnect the audio cord from the motherboard using a plastic opening tool.
    • When re-plugging this cord be sure it is flush with the slot, otherwise the speaker and directional pad will malfunction.
    • Use caution when unplugging, and re-plugging the ribbon cord as they are fragile.
  5. Leapfrog LeapPad 3 Display Assembly Replacement: 步骤 5 中的图像 1,3 Leapfrog LeapPad 3 Display Assembly Replacement: 步骤 5 中的图像 2,3 Leapfrog LeapPad 3 Display Assembly Replacement: 步骤 5 中的图像 3,3
    • Unscrew the five 6.0 mm phillips head screws from the board containing the audio jack and directional pad.
  6. Leapfrog LeapPad 3 Display Assembly Replacement: 步骤 6 中的图像 1,3 Leapfrog LeapPad 3 Display Assembly Replacement: 步骤 6 中的图像 2,3 Leapfrog LeapPad 3 Display Assembly Replacement: 步骤 6 中的图像 3,3
    • Unscrew the three 6.5 mm phillips head screws holding down the speaker to the right of the audio jack.
    • Remove the board and speaker from the device.
  7. Leapfrog LeapPad 3 Display Assembly Replacement, Motherboard: 步骤 7 中的图像 1,2 Leapfrog LeapPad 3 Display Assembly Replacement, Motherboard: 步骤 7 中的图像 2,2
    • Unplug the front facing camera cord with an opening tool to free the top of the motherboard.
  8. Leapfrog LeapPad 3 Display Assembly Replacement: 步骤 8 中的图像 1,3 Leapfrog LeapPad 3 Display Assembly Replacement: 步骤 8 中的图像 2,3 Leapfrog LeapPad 3 Display Assembly Replacement: 步骤 8 中的图像 3,3
    • Remove the three 6 mm phillips head screws holding the motherboard to the display assembly.
  9. Leapfrog LeapPad 3 Display Assembly Replacement: 步骤 9 中的图像 1,3 Leapfrog LeapPad 3 Display Assembly Replacement: 步骤 9 中的图像 2,3 Leapfrog LeapPad 3 Display Assembly Replacement: 步骤 9 中的图像 3,3
    • Carefully lift the motherboard out of the case, exposing the last remaining cord on the underside of the motherboard.
    • Disconnect the gold display assembly cord with an opening tool to fully disconnect the motherboard.
    • The device was rotated 180 degrees in order to unplug the display assembly cord.
  10. Leapfrog LeapPad 3 Display Assembly Replacement, Display Assembly: 步骤 10 中的图像 1,2 Leapfrog LeapPad 3 Display Assembly Replacement, Display Assembly: 步骤 10 中的图像 2,2
    • Unscrew the eight 6.5mm Phillips #0 screws from the plastic casing.
  11. Leapfrog LeapPad 3 Display Assembly Replacement: 步骤 11 中的图像 1,3 Leapfrog LeapPad 3 Display Assembly Replacement: 步骤 11 中的图像 2,3 Leapfrog LeapPad 3 Display Assembly Replacement: 步骤 11 中的图像 3,3
    • Remove the covering with your hands to allow full view of the display assembly.
  12. Leapfrog LeapPad 3 Display Assembly Replacement: 步骤 12 中的图像 1,3 Leapfrog LeapPad 3 Display Assembly Replacement: 步骤 12 中的图像 2,3 Leapfrog LeapPad 3 Display Assembly Replacement: 步骤 12 中的图像 3,3
    • Remove the display assembly from the black rubber sleeve carefully.
    • There is a specific orientation for the rubber sleeve so take note of its position.
结论
5等其他人完成本指南。
Matt Irvine
于02/04/16注册
952 声望
创作了6篇指南
团队
USF Tampa, Team 16-2, Blackwell Winter 2016 USF Tampa, Team 16-2, Blackwell Winter 2016 的会员
USFT-BLACKWELL-W16S16G2
3 名成员
创作了12篇指南
4条评论
Everything worked ok but unit now will not go to home page. after I replaced the display. They tell you necessary tools but never tell you where or how to use the wrist grounding strap.
Dave Alan - 回复
Bonjour, j’ai bien réussi à accéder à l’écran,
Ma question:
Oû peut-on se procurer un écran neuf SVP?
Gregory Commarmond - 回复
Pouvez vous m'indiquer où trouver un écran de remplacement ?
Merci d'avance
Domi Luky - 回复
OK, Visiblement ce tuto ne sert plus à rien car il est Impossible de trouver le display de remplacement!!
Domi Luky - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 1,058
