跳转到主内容
Leapfrog LeapPad 3 Battery Replacement
你所需要的
  1. Leapfrog LeapPad 3 Battery Replacement, Battery: 步骤 1 中的图像 1,3 Leapfrog LeapPad 3 Battery Replacement, Battery: 步骤 1 中的图像 2,3 Leapfrog LeapPad 3 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
    购买
    • Before taking apart your device, ensure that it is turned off and that your anti-static wrist strap is secured to a ground.
    • Remove the six 10.0 mm Phillips #0 screws from the outer case and remove the cover with your hands.
    • You will not need to pry the case off.
  2. Leapfrog LeapPad 3 Battery Replacement: 步骤 2 中的图像 1,3 Leapfrog LeapPad 3 Battery Replacement: 步骤 2 中的图像 2,3 Leapfrog LeapPad 3 Battery Replacement: 步骤 2 中的图像 3,3
    • Unplug the battery from the motherboard with your hands.
    • The battery sits to the right of the motherboard.
  3. Leapfrog LeapPad 3 Battery Replacement: 步骤 3 中的图像 1,2 Leapfrog LeapPad 3 Battery Replacement: 步骤 3 中的图像 2,2
    • Pry the battery gently off of the plastic platform with an opening tool.
    • Do not to puncture the battery, as the material inside can be dangerous.
结论
3等其他人完成本指南。
Matt Irvine
于02/04/16注册
952 声望
创作了6篇指南
团队
USF Tampa, Team 16-2, Blackwell Winter 2016 USF Tampa, Team 16-2, Blackwell Winter 2016 的会员
USFT-BLACKWELL-W16S16G2
3 名成员
创作了12篇指南
一条评论
where can i purchase a battery, i have googled and come up with nothing.
martinez2503 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 6
总计 4,269
