跳转到主内容
LeapPad Ultra Battery Replacement
你所需要的
  1. LeapPad Ultra Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the barcode covering the two screws on the lower back of the Leap Pad.
  2. LeapPad Ultra Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the two 5 mm screws that were covered by the sticker.
  3. LeapPad Ultra Battery Replacement: 步骤 3 中的图像 1,1
    • Using a plastic opening tool, pry off the outer protective child proof casing, starting from the bottom.
  4. LeapPad Ultra Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the 7 mm screw to the right of the cartridge dock, two 8 mm screws in the top left, and the nine 8 mm screws holding the the green shell.
  5. LeapPad Ultra Battery Replacement: 步骤 5 中的图像 1,1
    • Remove the hard plastic casing, exposing the motherboard and battery.
  6. LeapPad Ultra Battery Replacement: 步骤 6 中的图像 1,2 LeapPad Ultra Battery Replacement: 步骤 6 中的图像 2,2
    • Disconnect the battery using tweezers or your fingernails.
    • The battery is glued down, if available put some isopropyl alcohol around the edges of the battery to soften the glue.
    • Gently pry of the battery lose using a spudger or another thin prying tool.
    • Be careful, damaging/puncturing the battery may cause an explosion.
结论
To reassemble the device, follow these instructions in reverse order.
7等其他人完成本指南。
团队
USF Tampa, Team 4-99, Meier Fall 2015 USF Tampa, Team 4-99, Meier Fall 2015 的会员
USFT-MEIER-F15S4G99
4 名成员
创作了10篇指南
4条评论
Hi Ryan, will removing the battery delete any of the downloaded apps and saved files?
Michael - 回复
I’m not Ryan, but I just did this process and the apps and files are all still there.
Kivi Shapiro - 回复
What is a spudger and where do I get a battery
P Mac - 回复
Hello, if anyone still has this leappad Ultra and wanted to purchase a new battery. I have found a retail store https://batteryclerk.com/ The price is reasonable, and I'm just waiting for the batteries to arrive.
Mike Silva - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 26
总计 16,079
