跳转到主内容
LeapFrog Scribble and Write Motherboard Replacement
你所需要的
  1. LeapFrog Scribble and Write Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Use a Phillips head screwdriver to remove the screw from the battery compartment on the back of the toy.
  2. LeapFrog Scribble and Write Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the back battery cover and all of the batteries.
  3. LeapFrog Scribble and Write Motherboard Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips screwdriver to remove the nine case screws from the back of the toy.
    • Be careful to keep track of the screws.
  4. LeapFrog Scribble and Write Motherboard Replacement: 步骤 4 中的图像 1,1
    • Remove the back cover from your toy.
  5. LeapFrog Scribble and Write Motherboard Replacement: 步骤 5 中的图像 1,1
    • Using a Phillips screwdriver, remove the four screws from the motherboard.
  6. LeapFrog Scribble and Write Motherboard Replacement: 步骤 6 中的图像 1,1
    • Remove the keyboard ribbon from the motherboard.
  7. LeapFrog Scribble and Write Motherboard Replacement: 步骤 7 中的图像 1,1
    • Remove the speaker wires from the motherboard with your soldering iron.
  8. LeapFrog Scribble and Write Motherboard Replacement: 步骤 8 中的图像 1,1
    • Remove the battery wires from the motherboard with the soldering iron.
  9. LeapFrog Scribble and Write Motherboard Replacement: 步骤 9 中的图像 1,1
    • Remove the switch wires from the motherboard with the soldering iron.
  10. LeapFrog Scribble and Write Motherboard Replacement: 步骤 10 中的图像 1,1
    • Remove the pen wires from the motherboard with the soldering iron.
  11. LeapFrog Scribble and Write Motherboard Replacement: 步骤 11 中的图像 1,1
    • Remove the volume control switch from the motherboard with the soldering iron.
结论
另外一个人完成了本指南。
Shang
于02/10/16注册
328 声望
创作了3篇指南
团队
USF Tampa, Team 1-5, Nance Spring 2016 USF Tampa, Team 1-5, Nance Spring 2016 的会员
USFT-NANCE-S16S1G5
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 16
总计 642
