跳转到主内容
LeapFrog Scribble and Write Eraser Slider Cleaning
你所需要的
  1. LeapFrog Scribble and Write Eraser Slider Cleaning, Eraser Slider: 步骤 1 中的图像 1,1
    • Turn the toy over so the back is facing upward.
  2. LeapFrog Scribble and Write Eraser Slider Cleaning: 步骤 2 中的图像 1,1
    • Using a Phillips #0 screwdriver, carefully remove all 9 screws.
    • Set aside screws in a safe place for later reassembly.
  3. LeapFrog Scribble and Write Eraser Slider Cleaning: 步骤 3 中的图像 1,1
    • Remove the back of the toy by carefully lifting it up.
  4. LeapFrog Scribble and Write Eraser Slider Cleaning: 步骤 4 中的图像 1,2 LeapFrog Scribble and Write Eraser Slider Cleaning: 步骤 4 中的图像 2,2
    • Using a Phillips #0 screwdriver, remove the two screws that secure the screen to the motherboard.
    • Set aside screws in a safe place.
    • Gently remove the motherboard to expose the display screen and eraser slider.
  5. LeapFrog Scribble and Write Eraser Slider Cleaning: 步骤 5 中的图像 1,1
    • Carefully remove the display screen, leaving the eraser slider attached.
  6. LeapFrog Scribble and Write Eraser Slider Cleaning: 步骤 6 中的图像 1,2 LeapFrog Scribble and Write Eraser Slider Cleaning: 步骤 6 中的图像 2,2
    • Use the Phillips #0 screwdriver to remove the eraser slider.
  7. LeapFrog Scribble and Write Eraser Slider Cleaning: 步骤 7 中的图像 1,1
    • Lastly, use a soft towel to clean the eraser slider, removing any debris.
    • When all previous seven steps are completed, go backwards and re-screw and put together your The LeapFrog Scribble and Write
结论
Shang
于02/10/16注册
328 声望
创作了3篇指南
团队
USF Tampa, Team 1-5, Nance Spring 2016 USF Tampa, Team 1-5, Nance Spring 2016 的会员
USFT-NANCE-S16S1G5
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 7
总计 946
