跳转到主内容
LeapFrog LeapTV Controller Joy Stick Replacement
你所需要的
  1. LeapFrog LeapTV Controller Joy Stick Replacement, Battery: 步骤 1 中的图像 1,1
    • Use the Metal Spudger to push the release clip on the battery cover.
  2. LeapFrog LeapTV Controller Joy Stick Replacement: 步骤 2 中的图像 1,1
    • Lift the cover off.
  3. LeapFrog LeapTV Controller Joy Stick Replacement: 步骤 3 中的图像 1,1
    • The battery holder is now visible with the removal of the cover.
  4. LeapFrog LeapTV Controller Joy Stick Replacement, Controller Joy Stick: 步骤 4 中的图像 1,1
    • Use the screwdriver to remove the eight 8.7 mm PH1 Phillips head screws.
  5. LeapFrog LeapTV Controller Joy Stick Replacement: 步骤 5 中的图像 1,1
    • Separate the top and bottom parts of the controller slightly.
  6. LeapFrog LeapTV Controller Joy Stick Replacement: 步骤 6 中的图像 1,1
    • Slide the cover on the back side of the controller covering the joy stick out of the way.
  7. LeapFrog LeapTV Controller Joy Stick Replacement: 步骤 7 中的图像 1,1
    • Use the screwdriver to remove the four 8.7 mm PH1 Phillips head screws.
  8. LeapFrog LeapTV Controller Joy Stick Replacement: 步骤 8 中的图像 1,1
    • Turn and lift the circuit board with button attacked out of the hole. Do not detach the circuit.
  9. LeapFrog LeapTV Controller Joy Stick Replacement: 步骤 9 中的图像 1,1
    • Hold the circuit board and button and pull the button off.
  10. LeapFrog LeapTV Controller Joy Stick Replacement: 步骤 10 中的图像 1,1
    • Joystick will now pop off.
结论
Joshua Jones
于03/23/17注册
101 声望
撰写一个指南
团队
IUPUI, Team S4-G2, Baechle Spring 2017 IUPUI, Team S4-G2, Baechle Spring 2017 的会员
IUPUI-BAECHLE-S17S4G2
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 780
