跳转到主内容
加入维修社区 - 创建账户
LeapFrog LeapPad2 Explorer Back Cover Replacement
你所需要的
  1. LeapFrog LeapPad2 Explorer Back Cover Replacement, Battery: 步骤 1 中的图像 1,2 LeapFrog LeapPad2 Explorer Back Cover Replacement, Battery: 步骤 1 中的图像 2,2
    • Before disassembling your LeapPad, ensure your device is shut off.
    • Push outward on the plastic side panels to remove and reveal battery.
    • The panels should detach fully from the main device.
  2. LeapFrog LeapPad2 Explorer Back Cover Replacement: 步骤 2 中的图像 1,3 LeapFrog LeapPad2 Explorer Back Cover Replacement: 步骤 2 中的图像 2,3 LeapFrog LeapPad2 Explorer Back Cover Replacement: 步骤 2 中的图像 3,3
    • Push down from the positive end of the battery towards the negative end to pry the battery up out of its dispenser.
    • Remove all four AA alkaline batteries from the device.
  3. LeapFrog LeapPad2 Explorer Back Cover Replacement, Back Cover: 步骤 3 中的图像 1,2 LeapFrog LeapPad2 Explorer Back Cover Replacement, Back Cover: 步骤 3 中的图像 2,2
    • This step will void your device warranty.
    • Remove the following screws securing the back cover to the main device:
    • Two 10.0 mm Phillips screws
    • Four 4.0 mm Phillips screws
    • Three 3.0 mm Phillips screws
  4. LeapFrog LeapPad2 Explorer Back Cover Replacement: 步骤 4 中的图像 1,3 LeapFrog LeapPad2 Explorer Back Cover Replacement: 步骤 4 中的图像 2,3 LeapFrog LeapPad2 Explorer Back Cover Replacement: 步骤 4 中的图像 3,3
    • Insert a plastic opening tool into the seam between the front and rear covers to detach the back cover from the rest of the device.
    • Move the plastic opening tool around the perimeter of the LeapPad2.
    • Lift up and remove the rear case from the tablet.
    • A butter knife can help when prying the device.
结论
Nupur Garg
于04/12/14注册
867 声望
创作了7篇指南
团队
Cal Poly, Team 8-10, Regan Spring 2014 Cal Poly, Team 8-10, Regan Spring 2014 的会员
CPSU-REGAN-S14S8G10
4 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 36
总计 1,697
