跳转到主内容
LeapFrog LeapPad2 Explorer Back Camera Replacement
你所需要的
  1. LeapFrog LeapPad2 Explorer Back Camera Replacement, Battery: 步骤 1 中的图像 1,2 LeapFrog LeapPad2 Explorer Back Camera Replacement, Battery: 步骤 1 中的图像 2,2
    • Before disassembling your LeapPad, ensure your device is shut off.
    • Push outward on the plastic side panels to remove and reveal battery.
    • The panels should detach fully from the main device.
  2. LeapFrog LeapPad2 Explorer Back Camera Replacement: 步骤 2 中的图像 1,3 LeapFrog LeapPad2 Explorer Back Camera Replacement: 步骤 2 中的图像 2,3 LeapFrog LeapPad2 Explorer Back Camera Replacement: 步骤 2 中的图像 3,3
    • Push down from the positive end of the battery towards the negative end to pry the battery up out of its dispenser.
    • Remove all four AA alkaline batteries from the device.
  3. LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Cover: 步骤 3 中的图像 1,2 LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Cover: 步骤 3 中的图像 2,2
    • This step will void your device warranty.
    • Remove the following screws securing the back cover to the main device:
    • Two 10.0 mm Phillips screws
    • Four 4.0 mm Phillips screws
    • Three 3.0 mm Phillips screws
  4. LeapFrog LeapPad2 Explorer Back Camera Replacement: 步骤 4 中的图像 1,3 LeapFrog LeapPad2 Explorer Back Camera Replacement: 步骤 4 中的图像 2,3 LeapFrog LeapPad2 Explorer Back Camera Replacement: 步骤 4 中的图像 3,3
    • Insert a plastic opening tool into the seam between the front and rear covers to detach the back cover from the rest of the device.
    • Move the plastic opening tool around the perimeter of the LeapPad2.
    • Lift up and remove the rear case from the tablet.
    • A butter knife can help when prying the device.
  5. LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Camera: 步骤 5 中的图像 1,2 LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Camera: 步骤 5 中的图像 2,2
    • Locate the back camera below the game cartridge.
  6. LeapFrog LeapPad2 Explorer Back Camera Replacement: 步骤 6 中的图像 1,2 LeapFrog LeapPad2 Explorer Back Camera Replacement: 步骤 6 中的图像 2,2
    • To safely remove the ribbon cable, first you must pull up the retaining flap.
    • Removing or reinserting the cable by brute force can damage it.
  7. LeapFrog LeapPad2 Explorer Back Camera Replacement: 步骤 7 中的图像 1,2 LeapFrog LeapPad2 Explorer Back Camera Replacement: 步骤 7 中的图像 2,2
    • Pull up using a thin plastic tool to disconnect the ribbon connecting the camera to the motherboard.
  8. LeapFrog LeapPad2 Explorer Back Camera Replacement: 步骤 8 中的图像 1,1
    • Gently remove the back camera from your motherboard by pushing the black casing away from the camera.
结论
Nupur Garg
于04/12/14注册
867 声望
创作了7篇指南
团队
Cal Poly, Team 8-10, Regan Spring 2014 Cal Poly, Team 8-10, Regan Spring 2014 的会员
CPSU-REGAN-S14S8G10
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 1,141
