跳转到主内容
加入维修社区 - 创建账户
LeapFrog LeapPad2 Explorer Back Camera Replacement
你所需要的
    1. LeapFrog LeapPad2 Explorer Back Camera Replacement, Battery: 步骤 1 中的图像 1,2 LeapFrog LeapPad2 Explorer Back Camera Replacement, Battery: 步骤 1 中的图像 2,2
      • Before disassembling your LeapPad, ensure your device is shut off.
      • Push outward on the plastic side panels to remove and reveal battery.
      • The panels should detach fully from the main device.
      询问修复机器人
      添加评论
    2. LeapFrog LeapPad2 Explorer Back Camera Replacement: 步骤 2 中的图像 1,3 LeapFrog LeapPad2 Explorer Back Camera Replacement: 步骤 2 中的图像 2,3 LeapFrog LeapPad2 Explorer Back Camera Replacement: 步骤 2 中的图像 3,3
      • Push down from the positive end of the battery towards the negative end to pry the battery up out of its dispenser.
      • Remove all four AA alkaline batteries from the device.
      询问修复机器人
      添加评论
    1. LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Cover: 步骤 3 中的图像 1,2 LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Cover: 步骤 3 中的图像 2,2
      • This step will void your device warranty.
      • Remove the following screws securing the back cover to the main device:
      • Two 10.0 mm Phillips screws
      • Four 4.0 mm Phillips screws
      • Three 3.0 mm Phillips screws
      询问修复机器人
      添加评论
    2. LeapFrog LeapPad2 Explorer Back Camera Replacement: 步骤 4 中的图像 1,3 LeapFrog LeapPad2 Explorer Back Camera Replacement: 步骤 4 中的图像 2,3 LeapFrog LeapPad2 Explorer Back Camera Replacement: 步骤 4 中的图像 3,3
      • Insert a plastic opening tool into the seam between the front and rear covers to detach the back cover from the rest of the device.
      • Move the plastic opening tool around the perimeter of the LeapPad2.
      • Lift up and remove the rear case from the tablet.
      • A butter knife can help when prying the device.
      询问修复机器人
      添加评论
    1. LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Camera: 步骤 5 中的图像 1,2 LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Camera: 步骤 5 中的图像 2,2
      • Locate the back camera below the game cartridge.
      询问修复机器人
      添加评论
    2. LeapFrog LeapPad2 Explorer Back Camera Replacement: 步骤 6 中的图像 1,2 LeapFrog LeapPad2 Explorer Back Camera Replacement: 步骤 6 中的图像 2,2
      • To safely remove the ribbon cable, first you must pull up the retaining flap.
      • Removing or reinserting the cable by brute force can damage it.
      询问修复机器人
      添加评论
    3. LeapFrog LeapPad2 Explorer Back Camera Replacement: 步骤 7 中的图像 1,2 LeapFrog LeapPad2 Explorer Back Camera Replacement: 步骤 7 中的图像 2,2
      • Pull up using a thin plastic tool to disconnect the ribbon connecting the camera to the motherboard.
      询问修复机器人
      添加评论
    4. LeapFrog LeapPad2 Explorer Back Camera Replacement: 步骤 8 中的图像 1,1
      • Gently remove the back camera from your motherboard by pushing the black casing away from the camera.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Nupur Garg
于04/12/14注册
867 声望
创作了7篇指南
团队
Cal Poly, Team 8-10, Regan Spring 2014 Cal Poly, Team 8-10, Regan Spring 2014 的会员
CPSU-REGAN-S14S8G10
4 名成员
创作了18篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 27
总计 1,524
