跳转到主内容
LeapFrog LeapPad Ultra XDi Battery Replacement
你所需要的
  1. LeapFrog LeapPad Ultra XDi Battery Replacement, Battery: 步骤 1 中的图像 1,2 LeapFrog LeapPad Ultra XDi Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Orient the tablet so it’s laying screen down and the barcode sticker is facing up.
    • Remove the barcode sticker to expose the two screws.
  2. LeapFrog LeapPad Ultra XDi Battery Replacement: 步骤 2 中的图像 1,2 LeapFrog LeapPad Ultra XDi Battery Replacement: 步骤 2 中的图像 2,2
    • Remove the two 5.0mm Phillips #0 screws.
  3. LeapFrog LeapPad Ultra XDi Battery Replacement: 步骤 3 中的图像 1,3 LeapFrog LeapPad Ultra XDi Battery Replacement: 步骤 3 中的图像 2,3 LeapFrog LeapPad Ultra XDi Battery Replacement: 步骤 3 中的图像 3,3
    • Using the iFixit opening tool, pry off the purple and white child-proof casing to expose the twelve screws.
  4. LeapFrog LeapPad Ultra XDi Battery Replacement: 步骤 4 中的图像 1,2 LeapFrog LeapPad Ultra XDi Battery Replacement: 步骤 4 中的图像 2,2
    • Remove all twelve 7mm Phillips #1 screws located along the edges of the device.
  5. LeapFrog LeapPad Ultra XDi Battery Replacement: 步骤 5 中的图像 1,2 LeapFrog LeapPad Ultra XDi Battery Replacement: 步骤 5 中的图像 2,2
    • Remove the purple case, exposing the motherboard and battery.
  6. LeapFrog LeapPad Ultra XDi Battery Replacement: 步骤 6 中的图像 1,3 LeapFrog LeapPad Ultra XDi Battery Replacement: 步骤 6 中的图像 2,3 LeapFrog LeapPad Ultra XDi Battery Replacement: 步骤 6 中的图像 3,3
    • Use the Spudger to remove the glued down battery.
    • Using your fingers, grab the battery wires and carefully unplug them from the motherboard.
    • Replace the battery with a new one.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 19
总计 1,158
