跳转到主内容
LeapFrog LeapPad Ultra Repair Speaker Replacement
你所需要的
  1. LeapFrog LeapPad Ultra Repair Speaker Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the barcode covering the two screws on the lower back of the Leap Pad.
  2. LeapFrog LeapPad Ultra Repair Speaker Replacement: 步骤 2 中的图像 1,1
    • Remove the two 5 mm screws that were covered by the sticker.
  3. LeapFrog LeapPad Ultra Repair Speaker Replacement: 步骤 3 中的图像 1,1
    • Using a plastic opening tool, pry off the outer protective child proof casing, starting from the bottom.
  4. LeapFrog LeapPad Ultra Repair Speaker Replacement: 步骤 4 中的图像 1,1
    • Remove the 7 mm screw to the right of the cartridge dock, two 8 mm screws in the top left, and the nine 8 mm screws holding the the green shell.
  5. LeapFrog LeapPad Ultra Repair Speaker Replacement: 步骤 5 中的图像 1,1
    • Remove the hard plastic casing, exposing the motherboard and battery.
  6. LeapFrog LeapPad Ultra Repair Speaker Replacement: 步骤 6 中的图像 1,2 LeapFrog LeapPad Ultra Repair Speaker Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Disconnect the battery using tweezers or your fingernails.
    • The battery is glued down, if available put some isopropyl alcohol around the edges of the battery to soften the glue.
    • Gently pry of the battery lose using a spudger or another thin prying tool.
    • Be careful, damaging/puncturing the battery may cause an explosion.
  7. LeapFrog LeapPad Ultra Repair Speaker Replacement, Speaker: 步骤 7 中的图像 1,1
    • Find the screws on the bottom of the device holding down the button and speakers board.
  8. LeapFrog LeapPad Ultra Repair Speaker Replacement: 步骤 8 中的图像 1,2 LeapFrog LeapPad Ultra Repair Speaker Replacement: 步骤 8 中的图像 2,2
    • There should be a plastic covering over the speaker, carefully pull on the opposite side from the plastic clip holding it in place.
    • Excessive force can break the plastic clip, only use enough for to remove it gently
  9. LeapFrog LeapPad Ultra Repair Speaker Replacement: 步骤 9 中的图像 1,2 LeapFrog LeapPad Ultra Repair Speaker Replacement: 步骤 9 中的图像 2,2
    • Lift the button and speaker board, and turn it over, revealing the other side of the board.
  10. LeapFrog LeapPad Ultra Repair Speaker Replacement: 步骤 10 中的图像 1,2 LeapFrog LeapPad Ultra Repair Speaker Replacement: 步骤 10 中的图像 2,2
    • Find the ribbon cable connection and with a small plastic tool flip the plastic holding it down up.
    • You can now safely remove the ribbon cable by gently pulling it out of the slot.
    • Trying to remove the cable with brute force will damage the cable.
结论
Carlos Ortiz
于08/24/15注册
219 声望
撰写一个指南
团队
USF Tampa, Team 4-99, Meier Fall 2015 USF Tampa, Team 4-99, Meier Fall 2015 的会员
USFT-MEIER-F15S4G99
4 名成员
创作了10篇指南
一条评论
Where can i buy a replacement speaker at to do this?
anthonydesiato2002 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 6
总计 1,009
