当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Flip over the Pad to its back side to begin the removal of the back panel.
Begin by removing the blue rim along the edge of the device. It runs along the green silicone lining.
This is very difficult to remove , so do be patient. To help remove the seal, both a metal spudger and plastic opening tool may be used.
Remove the pen from its place before starting to avoid tangling.
Once the blue rim is removed, the 12 screws will be visible.
Use the Phillips #1 screwdriver to unscrew all 12 screws.
Begin with the removal of the battery from its place.
Flip the black switch that is connecting the battery to the motherboard.
Then pull gently and should disconnect.
Remove the black and white ribbon structures from the side of the motherboard.
Next, remove the three screws along the corners of the motherboard using the Phillips # 1 screwdriver.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
