跳转到主内容
LeapFrog LeapPad Ultimate Back Panel Replacement
你所需要的
  1. LeapFrog LeapPad Ultimate Back Panel Replacement, Back Panel: 步骤 1 中的图像 1,2 LeapFrog LeapPad Ultimate Back Panel Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Flip over the Pad to its back side to begin the removal of the back panel.
    • Begin by removing the blue rim along the edge of the device. It runs along the green silicone lining.
    • This is very difficult to remove , so do be patient. To help remove the seal, both a metal spudger and plastic opening tool may be used.
    • Remove the pen from its place before starting to avoid tangling.
  2. LeapFrog LeapPad Ultimate Back Panel Replacement: 步骤 2 中的图像 1,2 LeapFrog LeapPad Ultimate Back Panel Replacement: 步骤 2 中的图像 2,2
    • Once the blue rim is removed, the 12 screws will be visible.
    • Use the Phillips #1 screwdriver to unscrew all 12 screws.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 1,236
