简介
If your LeapPad is unable to produce sound, you can use this guide to replace your speaker. Make sure your device is turned off before disassembling it, and take extra caution to not damage any of the internal components (e.g. ribbon cables).
你所需要的
Wedge a plastic opening tool underneath the battery and lift the battery up.
How do you get that little black loop that the battery wires are wrapped in, out? Does it just pop out? I’m afraid to pull to hard
Remove the brown speaker board located on the left side of the LeapPad by removing the following screws holding it in place:
Four 3.0mm Phillips screws
One 7.0mm Phillips screw
2等其他人完成本指南。
many thanks for this, but can you tell me where to buy a replacement screen please?
Helen - 回复
