简介
If your LeapPad is unable to produce sound, you can use this guide to replace your speaker. Make sure your device is turned off before disassembling it, and take extra caution to not damage any of the internal components (e.g. ribbon cables).
你所需要的
Remove the brown speaker board located on the left side of the LeapPad by removing the following screws holding it in place:
Four 3.0mm Phillips screws
One 7.0mm Phillips screw
2等其他人完成本指南。
