跳转到主内容
LeapFrog LeapPad Platinum Battery Replacement
你所需要的
  1. LeapFrog LeapPad Platinum Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Place your tablet on a flat surface with the screen facing down.
  2. LeapFrog LeapPad Platinum Battery Replacement: 步骤 2 中的图像 1,2 LeapFrog LeapPad Platinum Battery Replacement: 步骤 2 中的图像 2,2
    • Using a plastic opening tool, pry off the plastic border by inserting it in the space between the green bumper and the white plastic on the edge of the tablet.
    • The border snaps into place, so don't be too worried if you hear a cracking noise while prying it off.
  3. LeapFrog LeapPad Platinum Battery Replacement: 步骤 3 中的图像 1,2 LeapFrog LeapPad Platinum Battery Replacement: 步骤 3 中的图像 2,2
    • Remove the 11 Phillips screws (8.0 mm) located around the edge of the back cover with a Phillips screwdriver.
  4. LeapFrog LeapPad Platinum Battery Replacement: 步骤 4 中的图像 1,1
    • Pull the back cover off of your device.
  5. LeapFrog LeapPad Platinum Battery Replacement: 步骤 5 中的图像 1,3 LeapFrog LeapPad Platinum Battery Replacement: 步骤 5 中的图像 2,3 LeapFrog LeapPad Platinum Battery Replacement: 步骤 5 中的图像 3,3
    • Wedge a plastic opening tool underneath the battery and lift the battery up.
    • The battery is held in place by an adhesive strip, so it can be difficult to pry off.
  6. LeapFrog LeapPad Platinum Battery Replacement: 步骤 6 中的图像 1,1
    • The battery has red, black, and white wires that are all connected to the motherboard through a plastic clip. Unplug this plastic clip to fully remove the battery from your device.
结论
2等其他人完成本指南。
团队
UW Tacoma, Team 1-5, Rose Winter 2016 UW Tacoma, Team 1-5, Rose Winter 2016 的会员
UWT-ROSE-W16S1G5
4 名成员
创作了8篇指南
3条评论
Any advice on how to fix a stylus go a leap pad platinum? The top is damaged- can I use any stylus or another platinum stylus it just buy a mesh tip? I can’t seem to find any too buy???
Ann-Mariah Thurber - 回复
The stylus is PART of the LeapPad so, there's no way to replace it.
Luke Sawczak -
This was very helpful thank you 😁
Luke Sawczak - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 19
总计 8,005
