跳转到主内容
LeapFrog LeapPad 32400 Motherboard Replacement
你所需要的
  1. LeapFrog LeapPad 32400 Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 LeapFrog LeapPad 32400 Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the tablet so the back is facing up.
    • Remove the battery covers by sliding the covers towards the sides and away from the center of the device.
  2. LeapFrog LeapPad 32400 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Take out the AA batteries from both battery compartments of the device.
    • Replace batteries as needed.
  3. LeapFrog LeapPad 32400 Motherboard Replacement, Back Panel: 步骤 3 中的图像 1,1
    • Remove three 7 mm screws using a Phillips #1 screwdriver.
    • Remove the single 6 mm screw using a Phillips #1 screwdriver.
    • Remove the single 10 mm screw using a Phillips #1 screwdriver.
  4. LeapFrog LeapPad 32400 Motherboard Replacement: 步骤 4 中的图像 1,3 LeapFrog LeapPad 32400 Motherboard Replacement: 步骤 4 中的图像 2,3 LeapFrog LeapPad 32400 Motherboard Replacement: 步骤 4 中的图像 3,3
    • Use a small plastic opening tool to separate the colored front cover from the white rear cover of the device.
    • With one hand on the front cover and one hand on the rear cover, start from the bottom of the device and pull the pieces apart.
    • Once only the top edge remains connected, pull the rear cover backwards away from the front cover and upwards towards the top of the device. This should release the last remaining tabs holding the pieces front and rear cover together.
    • The most stubborn tabs holding the front and rear together are along the top edge of the tablet around the game cartridge slot. This will most likely be the last area that separates, and it may require a moderate amount of force.
  5. LeapFrog LeapPad 32400 Motherboard Replacement: 步骤 5 中的图像 1,3 LeapFrog LeapPad 32400 Motherboard Replacement: 步骤 5 中的图像 2,3 LeapFrog LeapPad 32400 Motherboard Replacement: 步骤 5 中的图像 3,3
    • Separate the motherboard from the back side of the device by detaching the black and red wire connection from the back cover.
    • The two pieces that hold the pen in place will become loose. Remove and set aside for reassembly.
  6. LeapFrog LeapPad 32400 Motherboard Replacement, Motherboard: 步骤 6 中的图像 1,3 LeapFrog LeapPad 32400 Motherboard Replacement, Motherboard: 步骤 6 中的图像 2,3 LeapFrog LeapPad 32400 Motherboard Replacement, Motherboard: 步骤 6 中的图像 3,3
    • Remove the single 10 mm screw from the device using a Phillips #1 screwdriver.
    • Remove the single 7 mm screw from the device using a Phillips #1 screwdriver.
  7. LeapFrog LeapPad 32400 Motherboard Replacement: 步骤 7 中的图像 1,3 LeapFrog LeapPad 32400 Motherboard Replacement: 步骤 7 中的图像 2,3 LeapFrog LeapPad 32400 Motherboard Replacement: 步骤 7 中的图像 3,3
    • Unlatch the two battery terminals using a nylon spudger.
  8. LeapFrog LeapPad 32400 Motherboard Replacement: 步骤 8 中的图像 1,2 LeapFrog LeapPad 32400 Motherboard Replacement: 步骤 8 中的图像 2,2
  9. LeapFrog LeapPad 32400 Motherboard Replacement: 步骤 9 中的图像 1,3 LeapFrog LeapPad 32400 Motherboard Replacement: 步骤 9 中的图像 2,3 LeapFrog LeapPad 32400 Motherboard Replacement: 步骤 9 中的图像 3,3
    • Gently lift the motherboard away from the back cover.
    • Peel back the tape on the display ribbon cable connector.
    • Gently pull on the display ribbon cable and it should easily slide out of the connecter.
    • If the connector is properly open, disconnecting the ribbon cable should require little to no force.
结论
Aubra Sharp
于03/01/23注册
457 声望
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 59
