简介
In order to access and replace internal components such as the cameras, motherboard, or screen assembly, you must remove the back cover of the tablet.
你所需要的
Turn the tablet so the back is visible.
One at a time, remove the battery covers by sliding them towards the sides and away from the center of the device.
Use a Phillips #1 screwdriver to remove the following screws from the device:
Four 7.0mm Phillips screws
Three 6.0mm Phillips screws
Two 10.0mm Phillips screws
Use a small plastic opening tool to begin separating the colored front cover from the white rear cover of the device.
With one hand on the front cover and one hand on the rear cover, start from the bottom of the device and begin pulling the pieces apart.
Once only the top edge remains connected, simultaneously pull the rear cover backwards away from the front cover and upwards towards the top of the device. This should release the last remaining tabs holding the pieces together.
