跳转到主内容
N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide
你所需要的
  1. N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide, Leaf Spring Switch: 步骤 1 中的图像 1,1
    • Place the blaster upside down on the table, and remove the screw in the bottom of the handle.
    • Remove the battery door and take the batteries out.
  2. N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide: 步骤 2 中的图像 1,3 N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide: 步骤 2 中的图像 2,3 N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide: 步骤 2 中的图像 3,3
    • Set the blaster on its side with the screws facing up (the blaster will be placed on its left side). Remove all 14 phillips head, 8.2 mm screws and set them aside.
    • Lift the side of the blaster off exposing its internal parts.
  3. N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide: 步骤 3 中的图像 1,1
    • Work the trigger to ensure the problem is the switch not making a proper connection.
    • Remove the retaining phillips head 10.2 mm screw below the switch.
  4. N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide: 步骤 4 中的图像 1,1
    • Use a hot soldering iron to melt the solder of the two wires at the rear of the switch. Take note that the red wire leads from the top of the switch.
结论
另外一个人完成了本指南。
团队
Michigan Tech, Team 5-8, Lauer Spring 2014 Michigan Tech, Team 5-8, Lauer Spring 2014 的会员
MTU-LAUER-S14S5G8
3 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 1,947
