跳转到主内容
Leader Impression i10A-LE Speakers Replacement
你所需要的
  1. Leader Impression i10A-LE Speakers  Replacement, Speakers: 步骤 1 中的图像 1,1
    • Start with your Leader Impression i10A-LE with the word "Impression" closest to you and the camera in the top left corner.
  2. Leader Impression i10A-LE Speakers  Replacement: 步骤 2 中的图像 1,3 Leader Impression i10A-LE Speakers  Replacement: 步骤 2 中的图像 2,3 Leader Impression i10A-LE Speakers  Replacement: 步骤 2 中的图像 3,3
    • Start by prying the back off by using plastic opening tools
    • Using the plastic tools slide the flat end into the device.
    • Gently pry the back piece until you hear a popping noise.
    • Once the back is loose, remove it from the device and set aside.
  3. Leader Impression i10A-LE Speakers  Replacement: 步骤 3 中的图像 1,3 Leader Impression i10A-LE Speakers  Replacement: 步骤 3 中的图像 2,3 Leader Impression i10A-LE Speakers  Replacement: 步骤 3 中的图像 3,3
    • Use the spudger to pry both of the speakers from the tablet.
    • Follow both sets of speaker wires to the motherboard where they are connected.
    • Desolder the wire connections from the motherboard.
结论
jcg
于11/14/16注册
101 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 8
总计 129
