跳转到主内容
Leader Impression i10A-LE Microphone Replacement
你所需要的
  1. Leader Impression i10A-LE Microphone Replacement, Microphone: 步骤 1 中的图像 1,1
    • Orient your Leader Impression i10A-LE with the word "Impression" closest to you and the camera in the top left corner.
  2. Leader Impression i10A-LE Microphone Replacement: 步骤 2 中的图像 1,3 Leader Impression i10A-LE Microphone Replacement: 步骤 2 中的图像 2,3 Leader Impression i10A-LE Microphone Replacement: 步骤 2 中的图像 3,3
    • Pry the back off by using plastic opening tools.
    • Using the plastic tools slide the flat end into the device.
    • Gently pry the back piece until you hear a popping noise.
    • Once the back is loose, remove it from the device and set aside.
  3. Leader Impression i10A-LE Microphone Replacement: 步骤 3 中的图像 1,2 Leader Impression i10A-LE Microphone Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Disconnect the positive and negative battery leads.
    • Remove the microphone from plastic housing with the tweezers.
    • Desolder the positive (red) and negative (black) power leads.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 6
总计 114
