跳转到主内容
Leader Impression i10A-LE Front Facing Camera Replacement
你所需要的
  1. Leader Impression i10A-LE Front Facing Camera Replacement, Front Facing Camera: 步骤 1 中的图像 1,2 Leader Impression i10A-LE Front Facing Camera Replacement, Front Facing Camera: 步骤 1 中的图像 2,2
    • Start by prying the back off by using plastic opening tools.
    • Slide the flat end of the plastic tools into the seam device.
    • Using another plastic tool, slowly pry along the seam until the back pops off.
  2. Leader Impression i10A-LE Front Facing Camera Replacement: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Reminder to disconnect the battery.
    • Locate the Camera in the top left corner of the Leader Impression.
    • Using the tweezers, remove the bottom of the camera from the motherboard.
    • The top of the camera will detach as you pull upward.
  3. Leader Impression i10A-LE Front Facing Camera Replacement: 步骤 3 中的图像 1,1
    • Remove the camera from it's slot.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 10
总计 122
