跳转到主内容
Leader Impression i10A-LE Battery Pack Replacement
你所需要的
  1. Leader Impression i10A-LE Battery Pack Replacement, Battery Pack: 步骤 1 中的图像 1,1
    • Start with your Leader Impression i10A-LE with the word "Impression" closest to you and the camera in the top left corner.
  2. Leader Impression i10A-LE Battery Pack Replacement: 步骤 2 中的图像 1,3 Leader Impression i10A-LE Battery Pack Replacement: 步骤 2 中的图像 2,3 Leader Impression i10A-LE Battery Pack Replacement: 步骤 2 中的图像 3,3
    • Use the plastic prying tools to crack open the back of the device.
    • Once cracked, use more plastic prying tools to fully remove the back panel. A popping noise will occur when each clip is opened.
    • Remove the back panel and set aside.
  3. Leader Impression i10A-LE Battery Pack Replacement: 步骤 3 中的图像 1,2 Leader Impression i10A-LE Battery Pack Replacement: 步骤 3 中的图像 2,2
    • The battery pack is glued to the device.
    • Use a spudger to pry the battery pack from the glue.
    • Desolder the positive (red) and negative (black) power leads.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 9
总计 574
