跳转到主内容
Leader Impression i10A-LE Back Facing Camera Replacement
你所需要的
  1. Leader Impression i10A-LE Back Facing Camera Replacement, Back Facing Camera: 步骤 1 中的图像 1,2 Leader Impression i10A-LE Back Facing Camera Replacement, Back Facing Camera: 步骤 1 中的图像 2,2
    • Start with your Leader Impression i10A-LE with the word "Impression" closest to you and the camera in the top left corner.
  2. Leader Impression i10A-LE Back Facing Camera Replacement: 步骤 2 中的图像 1,3 Leader Impression i10A-LE Back Facing Camera Replacement: 步骤 2 中的图像 2,3 Leader Impression i10A-LE Back Facing Camera Replacement: 步骤 2 中的图像 3,3
    • Start by prying the back off by using plastic opening tools.
    • Using the plastic tools slide the flat end into the device.
    • Gently pry the back piece until you hear a popping noise.
    • Once the back is loose, remove it from the device and set aside.
  3. Leader Impression i10A-LE Back Facing Camera Replacement: 步骤 3 中的图像 1,3 Leader Impression i10A-LE Back Facing Camera Replacement: 步骤 3 中的图像 2,3 Leader Impression i10A-LE Back Facing Camera Replacement: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Once the back is off, locate the back facing camera.
    • The camera will be in the top left corner.
    • Using the precision tweezers that are bent, gently grab the strip below the camera.
    • slowly lift up until the camera lifts from its spot.
  4. Leader Impression i10A-LE Back Facing Camera Replacement: 步骤 4 中的图像 1,3 Leader Impression i10A-LE Back Facing Camera Replacement: 步骤 4 中的图像 2,3 Leader Impression i10A-LE Back Facing Camera Replacement: 步骤 4 中的图像 3,3
    • Continue slowly lifting with the bent precision tweezers.
    • The bottom half of the camera strip will pop out.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 9
总计 202
