简介
Follow this tutorial in order to easily replace the loudspeaker in your Pave Parisien.
Lift the speaker out of the concrete shell in order to access the connections.
To disconnect the speker, pull each of the cables, gripping the connector and easing it from side to side.
You only have to connect the replacement speaker and follow the instructions in reverse in order to reassemble your Pavé Parisien.
Connect the speaker as in step 3. Take care to ensure the connectors are on the side where there is a notch in the concrete.
You only have to replace the screws and the protective grill and your Pavé Parisien is reassembled!
Follow these instruction in reverse order to reassemble your device.
另外一个人完成了本指南。
由衷感谢以下译者:
100%
Philip Le Riche正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
