跳转到主内容
Le Pan S Volume Rocker Replacement
你所需要的
  1. Le Pan S Volume Rocker Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the two 3.5 mm Phillips #00 screws that are covered by the micro SD port.
    • This cover is adjacent to the volume button on the side of the Le Pan S.
  2. Le Pan S Volume Rocker Replacement: 步骤 2 中的图像 1,2 Le Pan S Volume Rocker Replacement: 步骤 2 中的图像 2,2
    • Insert the spudger between the front and back panel in order to pry them apart.
    • Do this beside the volume button and the micro SD cover.
    • Pry open the rest of the Le Pan S by dragging the spudger across the side.
  3. Le Pan S Volume Rocker Replacement: 步骤 3 中的图像 1,1
    • Once the front and back faces are completely separated, remove the back cover to reveal the inside components.
  4. Le Pan S Volume Rocker Replacement: 步骤 4 中的图像 1,2 Le Pan S Volume Rocker Replacement: 步骤 4 中的图像 2,2
    • Disconnect the battery from the circuitry and lay it out of the way.
    • The best method to complete this is to pull the bundled cable connector out with your hands. Pull towards the wires and away from the electrical board. Use the spudger to further coax the cable out.
    • If you are replacing your battery, make sure to dispose of it properly.
  5. Le Pan S Volume Rocker Replacement, Volume Rocker: 步骤 5 中的图像 1,1
    • Remove the four 2.5 mm Phillips #00 head screws from the circuit board near the top of the tablet.
  6. Le Pan S Volume Rocker Replacement: 步骤 6 中的图像 1,1
    • Pull out the volume rocker by carefully moving it side to side with your fingers.
结论
另外一个人完成了本指南。
团队
IUPUI, Team 2-1, Harley Fall 2015 IUPUI, Team 2-1, Harley Fall 2015 的会员
IUPUI-HARLEY-F15S2G1
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 215
