跳转到主内容
Le Pan S Camera Replacement
你所需要的
  1. Le Pan S Camera Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the two 3.5 mm Phillips #00 screws that are covered by the micro SD port.
    • This cover is adjacent to the volume button on the side of the Le Pan S.
  2. Le Pan S Camera Replacement: 步骤 2 中的图像 1,2 Le Pan S Camera Replacement: 步骤 2 中的图像 2,2
    • Insert the spudger between the front and back panel in order to pry them apart.
    • Do this beside the volume button and the micro SD cover.
    • Pry open the rest of the Le Pan S by dragging the spudger across the side.
  3. Le Pan S Camera Replacement: 步骤 3 中的图像 1,1
    • Once the front and back faces are completely separated, remove the back cover to reveal the inside components.
  4. Le Pan S Camera Replacement: 步骤 4 中的图像 1,2 Le Pan S Camera Replacement: 步骤 4 中的图像 2,2
    • Disconnect the battery from the circuitry and lay it out of the way.
    • The best method to complete this is to pull the bundled cable connector out with your hands. Pull towards the wires and away from the electrical board. Use the spudger to further coax the cable out.
    • If you are replacing your battery, make sure to dispose of it properly.
  5. Le Pan S Camera Replacement, Camera: 步骤 5 中的图像 1,1
    • Remove the four 3.5 mm Phillips #00 screws from the circuit board near the bottom of the tablet.
  6. Le Pan S Camera Replacement: 步骤 6 中的图像 1,1
    • Lift and pull the volume rocker up so it is out of the way of the camera.
  7. Le Pan S Camera Replacement: 步骤 7 中的图像 1,2 Le Pan S Camera Replacement: 步骤 7 中的图像 2,2
    • Remove the zero insertion force connector (ZIF) by using a plastic opening tool, spudger, or fingernail to lift retaining flap.
  8. Le Pan S Camera Replacement: 步骤 8 中的图像 1,2 Le Pan S Camera Replacement: 步骤 8 中的图像 2,2
    • Slightly lift up the green electrical board and pull out the camera.
结论
Tyler Ziliak
于09/17/15注册
110 声望
撰写一个指南
团队
IUPUI, Team 2-1, Harley Fall 2015 IUPUI, Team 2-1, Harley Fall 2015 的会员
IUPUI-HARLEY-F15S2G1
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 237
