跳转到主内容
Le Pan S Battery Replacement
你所需要的
  1. Le Pan S Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the two 3.5 mm Phillips #00 screws that are covered by the micro SD port.
    • This cover is adjacent to the volume button on the side of the Le Pan S.
  2. Le Pan S Battery Replacement: 步骤 2 中的图像 1,2 Le Pan S Battery Replacement: 步骤 2 中的图像 2,2
    • Insert the spudger between the front and back panel in order to pry them apart.
    • Do this beside the volume button and the micro SD cover.
    • Pry open the rest of the Le Pan S by dragging the spudger across the side.
  3. Le Pan S Battery Replacement: 步骤 3 中的图像 1,1
    • Once the front and back faces are completely separated, remove the back cover to reveal the inside components.
  4. Le Pan S Battery Replacement: 步骤 4 中的图像 1,2 Le Pan S Battery Replacement: 步骤 4 中的图像 2,2
    • Disconnect the battery from the circuitry and lay it out of the way.
    • The best method to complete this is to pull the bundled cable connector out with your hands. Pull towards the wires and away from the electrical board. Use the spudger to further coax the cable out.
    • If you are replacing your battery, make sure to dispose of it properly.
结论
3等其他人完成本指南。
Maria Dole
于09/17/15注册
395 声望
创作了3篇指南
团队
IUPUI, Team 2-1, Harley Fall 2015 IUPUI, Team 2-1, Harley Fall 2015 的会员
IUPUI-HARLEY-F15S2G1
5 名成员
创作了10篇指南
5条评论
where can I purchase a battery for a tc978
Timothy - 回复
Hi Timothy, Did you ever find out where to purchase a battery for your Le Pan S tablet?
jatrussel -
But what do I do when it's not the battery, but is the charger is so loose in the tablet, it won;t charge. Once in a while, I can get it to come on if I happened to hold the charger just right. So disgusting. Can this be fixed.? i have purchased two LePans and neither will charge.
cdboers - 回复
Where can I purchase the battery needed?????????????????
jatrussel - 回复
Thank you Maria!
Easy to take apart. Disconnected/reconnected battery and voila!
All good.
Be well.
Den E
Denny Ehlers - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 5,322
