跳转到主内容
加入维修社区 - 创建账户
Le Pan II Battery Replacement
你所需要的
  1. Le Pan II Battery Replacement, Screen: 步骤 1 中的图像 1,2 Le Pan II Battery Replacement, Screen: 步骤 1 中的图像 2,2
    • Insert metal spudger between front and back panel to pry apart.
    • Continue to pry while moving the metal spudger along the crevice to completely separate two panels.
    • Avoid using metal when opening devices, as it can damage or crack the screen.
  2. Le Pan II Battery Replacement: 步骤 2 中的图像 1,2 Le Pan II Battery Replacement: 步骤 2 中的图像 2,2
    • Use the plastic opening tool to disconnect the flat ribbon cable from the motherboard connector.
    • Disconnect the flat ribbon by gently pulling it out from its connecting port.
  3. Le Pan II Battery Replacement: 步骤 3 中的图像 1,2 Le Pan II Battery Replacement: 步骤 3 中的图像 2,2
    • Use the plastic opening tool to disconnect the display cable from its motherboard connector.
    • Disconnect the display cable by gently pulling it out from its connecting port.
  4. Le Pan II Battery Replacement: 步骤 4 中的图像 1,1
    • Remove grey metal backing from screen.
  5. Le Pan II Battery Replacement: 步骤 5 中的图像 1,1
    • Flip the tablet so the screen is facing upward, and use the metal spudger to pry apart the screen from the side pieces.
  6. Le Pan II Battery Replacement: 步骤 6 中的图像 1,1
    • Lift and carefully remove the LCD display from the front cover.
  7. Le Pan II Battery Replacement, Battery: 步骤 7 中的图像 1,1
    • Use the plastic opening tool to push out the wires connecting the battery to the motherboard and put battery aside.
结论
Kelly Moniz
于10/20/16注册
525 声望
创作了5篇指南
团队
UMass Dartmouth, Team 6-3, Martin Fall 2016 UMass Dartmouth, Team 6-3, Martin Fall 2016 的会员
UMASSD-MARTIN-F16S6G3
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 23
总计 1,653
