跳转到主内容
Lasergrip 1080 Sensor Replacement
你所需要的
  1. Lasergrip 1080 Sensor Replacement, Battery: 步骤 1 中的图像 1,1
    • Pull the battery cover away from the handle by gripping near the thumb groove.
  2. Lasergrip 1080 Sensor Replacement: 步骤 2 中的图像 1,1
    • Gently pull the battery out of the handle.
    • Excessive force could damage wires.
  3. Lasergrip 1080 Sensor Replacement: 步骤 3 中的图像 1,2 Lasergrip 1080 Sensor Replacement: 步骤 3 中的图像 2,2
    • Disconnect the battery by pulling the connector away from it.
    • Positive first
    • Negative second
    • When replacing the battery, this order is reversed.
  4. Lasergrip 1080 Sensor Replacement, Buttons: 步骤 4 中的图像 1,2 Lasergrip 1080 Sensor Replacement, Buttons: 步骤 4 中的图像 2,2
    • Remove the battery cover from the device by pulling it straight out.
  5. Lasergrip 1080 Sensor Replacement: 步骤 5 中的图像 1,2 Lasergrip 1080 Sensor Replacement: 步骤 5 中的图像 2,2
    • Using the plastic opening tool remove the front and rear yellow covers.
    • When removing the back cover, be careful not to lose the buttons as they are not connected.
  6. Lasergrip 1080 Sensor Replacement: 步骤 6 中的图像 1,1
    • Remove the two 3.1 mm Phillips #0 screws.
  7. Lasergrip 1080 Sensor Replacement: 步骤 7 中的图像 1,2 Lasergrip 1080 Sensor Replacement: 步骤 7 中的图像 2,2
    • Pull the two halves apart.
    • Be careful not to lose any components on the inside.
  8. Lasergrip 1080 Sensor Replacement: 步骤 8 中的图像 1,1
    • Realign the buttons with the button terminals.
    • Red terminal to red button.
    • Orange terminal to orange button.
    • Yellow terminal to yellow button.
  9. Lasergrip 1080 Sensor Replacement, Etekcity Lasergrip 1080 Trigger Replacement: 步骤 9 中的图像 1,2 Lasergrip 1080 Sensor Replacement, Etekcity Lasergrip 1080 Trigger Replacement: 步骤 9 中的图像 2,2
    • Carefully pull the trigger out.
    • The trigger is spring loaded, so be careful that you do not lose the spring as you pull the trigger out.
    • To put the trigger back in, align the peg with the hole in the handle and align the shaft with the button terminal.
  10. Lasergrip 1080 Sensor Replacement, Sensor: 步骤 10 中的图像 1,1
    • Pull the motherboard out of its slot in the device.
  11. Lasergrip 1080 Sensor Replacement: 步骤 11 中的图像 1,1
    • Using a soldering iron, melt the solder that holds the wires for the sensor to the motherboard.
    • Soldering irons are hot and should only be handled by those who know what they are doing and are wearing proper safety equipment. There is a link to a soldering guide in the Troubleshooting section of the device page.
结论
另外一个人完成了本指南。
Carlos Lewis
于08/27/15注册
162 声望
撰写一个指南
团队
USF Tampa, Team 5-1, Blackwell Fall 2015 USF Tampa, Team 5-1, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S5G1
3 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 14
总计 1,532
