跳转到主内容
修复你的物品
维修的权力
商店
简介
The default values of the PS1 drives are between 940 - 970 ohms. To read burned CDs you have to go down a bit.
Warning ! Before you work on the open console, be sure to remove the power! Pull the plug!
Reducing the resistance, will increase the wear and tear of the laser ! If you go down in steps of ten and the CD is read correctly do not further reduce the value, that is useless.
CD's MUST be burned with a maximum burning speed of 4x, because the PS1 laser cannot deal with burn errors. If your burner only supports higher speeds, get another one, because then the games will most likely not work.
This Tweak is intended for 7000er consoles (750x, 700x)! Other PS1 consoles may have a bias & gain on the motherboard. If this value is adjusted then there are other instructions for it.
视频介绍
结论
Feedback and constructive criticism desired.
3等其他人完成本指南。
特别感谢这些译者︰
100%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
TheSupport
于2016年03月27日注册
71 信誉积分
撰写一个指南
Swap to German ( ENGLISH TRANSLATION)
The default values ​​of the PS1 drives are between 940 - 970 ohms. To read burned CDs you have to go down a bit.Attention ! Before working on the open console, be sure to take the POWER away! Pull the plug!If you reduce the resistance value, the wear of the laser is increased! If you go down in steps of ten and the CD is read correctly does not reduce the value, that does not help.CD's MUST be burned with a maximum burning speed of 4x, because the PS1 laser with burn errors are not clear. If your burner only supports higher speeds, get another one, because then the games will most likely not work.This Tweak is for 7000er consoles intended (750x, 700x)! Other PS1 consoles may have a bias & gain on the motherboard. If this value is adjusted then there are other instructions for it.
Jordon Garcia - 回复
A modern DVD burner drive cant’t burn a CD-R at 4x. I have some old Taiyo Yuden CD-R (the type recommended for burning playstation backups). I was able to burn a game at the lowest allowed speed for that drive - 16x, and it worked just fine in the Playstation (with mod chip).
Leif Behrmann - 回复
添加评论
浏览统计数据:
过去的24小时: 6
过去的7天: 24
过去的30天: 125
总计 1,877
