跳转到主内容
Laptop Ram/Memory Replacement
你所需要的
  1. Laptop Ram/Memory Replacement, RAM door: 步骤 1 中的图像 1,3 Laptop Ram/Memory Replacement, RAM door: 步骤 1 中的图像 2,3 Laptop Ram/Memory Replacement, RAM door: 步骤 1 中的图像 3,3
    • Many laptops have a door for the ram. But often, removing the entire back cover is necessary.
    • Remove screws on Ram door.
    • There is now access to the ram.
    • Remember to always remove or disconnect the battery!
  2. Laptop Ram/Memory Replacement, Releasing the SODIMM: 步骤 2 中的图像 1,1
    • Push metal tab out of the way. Some laptops have screws instead of tabs.
  3. Laptop Ram/Memory Replacement, Removing the RAM: 步骤 3 中的图像 1,3 Laptop Ram/Memory Replacement, Removing the RAM: 步骤 3 中的图像 2,3 Laptop Ram/Memory Replacement, Removing the RAM: 步骤 3 中的图像 3,3
    • lift up on ram.
    • Pull out of SODIMM socket.
  4. Laptop Ram/Memory Replacement, Removing second stick: 步骤 4 中的图像 1,1
    • Repeat with second stick. Sometimes the second stick is layered under the first.
  5. Laptop Ram/Memory Replacement, Replacing the RAM: 步骤 5 中的图像 1,1
    • Remember, If only replacing one Stick, to put that stick in DIMM A or DIMM 1.
    • There are five types of laptop laptop ram: DDR, DDR2, DDR3, DDR3L, and DDR4.
    • Make sure that whatever ram your laptop was using is replaced by that same type. Memory is not cross compatible with desktop memory, so make sure that your RAM is SODIMM laptop memory. SODIMMs are usually about 3" long, while desktop DIMMs are about 4"-5" long.
  6. Laptop Ram/Memory Replacement, Putting the Memory Back: 步骤 6 中的图像 1,3 Laptop Ram/Memory Replacement, Putting the Memory Back: 步骤 6 中的图像 2,3 Laptop Ram/Memory Replacement, Putting the Memory Back: 步骤 6 中的图像 3,3
    • Re-insert RAM at a 45 degree angle and push down until clips snap into place or screw back in.
    • Make sure that pins line up correctly and memory is all the way in place.
    • This is incorrect.
    • Replace RAM door.
终点
11等其他人完成本指南。
George A.
于12/07/16注册
21,879 声望
创作了4篇指南
团队
Community Protectors Community Protectors 的会员
Community
19 名成员
创作了24篇指南
2条评论
Thank you! Your photographs and simple directions gave me the courage to try this. It’s kind of exhilarating to see those memory sticks pop up and then to hear them click in.
Christie Sonmez - 回复
@curiousandcheap I'm glad I could help! It's really one of the simplest upgrades you can do as long as your laptop doesn't specifically block access to the RAM compartment, but most brands make a door like the one shown to make it easier.
George A. - 回复
添加评论
浏览统计数据:
过去 24 小时: 13
过去 7 天: 91
过去 30 天: 347
总计 24,099
