跳转到主内容
Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement
你所需要的
  1. Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement, Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone: 步骤 1 中的图像 1,2 Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement, Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone: 步骤 1 中的图像 2,2
    • Switch off the grinder's breaker box before performing any maintenance on the machine.
  2. Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 步骤 2 中的图像 1,2 Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 步骤 2 中的图像 2,2
    • Lift the yellow guard up to unlock the grindstone access panel.
  3. Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 步骤 3 中的图像 1,2 Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 步骤 3 中的图像 2,2
    • Pull the access panel outward to expose the grindstone.
  4. Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 步骤 4 中的图像 1,2 Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 步骤 4 中的图像 2,2
    • Remove the twelve bolts securing the grindstone using a ratchet with a 5/16 Hex bit.
  5. Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 步骤 5 中的图像 1,2 Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 步骤 5 中的图像 2,2
    • Gently remove the steel hub from the grindstone spindle.
  6. Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 步骤 6 中的图像 1,2 Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 步骤 6 中的图像 2,2
    • Carefully remove the grindstone itself from the spindle, making sure to support it from the top and inner ring.
    • Mind your fingers! The grindstone is quite heavy and can cause injury if it is mishandled or dropped.
  7. Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 步骤 7 中的图像 1,2 Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 步骤 7 中的图像 2,2
    • Softly sand the hub with 600-grit sandpaper or a wire brush to remove any surface rust.
  8. Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 步骤 8 中的图像 1,1
    • Although not mandatory, now would be a good time to scrape out any debris that has built up on the inside of the guard.
结论
To reassemble your device, follow these instructions in reverse order starting from step 6.
3等其他人完成本指南。
团队
Texas Tech, Team 22-3, Rauch Spring 2016 Texas Tech, Team 22-3, Rauch Spring 2016 的会员
TTU-RAUCH-S16S22G3
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 45
总计 988
